Lift cylinders are in parallel. Cylinder piston condition (packing sealing capability) has to be identical. If you have one rebuilt cylinder and one worn out cylinder you can"t expect the worn out cylinder to suck it up (close the gate) like the rebuilt one does. On the lazy side, rebuild the cylinder. Bet you don"t know how I know this? Grin. The rest of the story. The kits were like $65. I had a JD 95 combine once and rebuilt all the hydraulics. Encountered every imaginable type of cylinder with each having a diferent method to access the innerds! Been awhile and I forgot what I learned. So I start in on my 530 and get into the "good" cylinder first. Why? Because it was on the side of the baler next to the work bench. In the process of relearning the process, I unknowingly selected the wrong cylinder...senior moment I guess cause I bought the kits cause of what we are talking about. So, in the process of repairing the good one, I tore up the new seal upon reinsertion of the ram into the cylinder. So I reluctantly used the seal from the second kit destined for the other side. Finished that one, took the other apart just to see how bad it was. Well, it was really worn out and should have been the one that I replaced first....had I paid attention to which side of the gate that wasn"t locking I"d have known.....but that was quite awhile before I bought the kits as this was a winter project. So I wound up taking the worn seal from the better cylinder (which someone had obviously rebuilt before) and installed in the weak cylinder. It passed the operational tests after the repair but has not been field tested. If it doesn"t work I will have to go back and get another $65 kit just to get the plastic seal out of it. Oh well. Mark
