John Deere 490 Planter Part
MinnesotanH
03-19-2008 18:40:08
I am looking for a particualr part from a JD 490 corn planter. It is part # 1802 and it is a Lift Clutch Crank casting. It used on the trip clutch for raising and lowering the runners. Is there any online sites or anywhere/anyone that can still find any of these parts? The rest of the planter is great, but this part is the one I need.
Thanks
Minnesotan H
farmerweber in PA
03-20-2008 22:25:14
 Re: John Deere 490 Planter Part in reply to MinnesotanH, 03-19-2008 18:40:08
Kind of off the subject,but you wouldn't happen to have a hyraulic lift for a 290?Like finding hens teeth.Thanks
Leroy
03-20-2008 16:55:29
Would you want used or does it have to be new? Without hunting up books I cannot tell for sure what part it is you need and the 490 used 2 different clutches so I am not sure of the clutch you have. On one the drive chain has a sprocket tooth for every chain link will the other the sprocket tooth skips every other link. I have a planter of each kind setting here.
MinnesotanH
03-22-2008 16:15:56
 Re: John Deere 490 Planter Part in reply to Leroy, 03-20-2008 16:55:29
Hey Leroy, The part I need is the for the sproket that skips a tooth. I need the part that connects the arm from the clutch to the 'rod' that pulls the chains for the runners/seed boxes. It a small piece that slides on that shaft. If you have one that would be great, used would be great. If youo have any questions, give me an email, [email protected]
Leroy
03-23-2008 16:26:30
 Re: John Deere 490 Planter Part in reply to MinnesotanH, 03-22-2008 16:15:56
You have mail.
