Fuse blowing
Rene Salinas
03-18-2008 20:53:19
I have a New Holland TC40 (2001). I am having trouble finding out what is causing the 7.5 operator safety fuse from blowing. I can move the PTO handle away from the NO switch and the fuse will not blow when I try starting up the tractor, but ofcourse will not start because it senses that the PTO is engaged. Confused in Texas??
RickB
03-19-2008 13:51:40
 Re: Fuse blowing in reply to Rene Salinas, 03-18-2008 20:53:19
Replace the fuse with an 8 amp blade style circuit breaker from your favorite auto parts house or NH dealer. This is the NH authorized fix for the fuse problem on class II and III compacts.
soundguy
03-19-2008 08:25:48
Pop a 10a fuse in there.
there has been lots of discussion of this over on TBN forum.. I believe there is a dealer fix for this by using a crcuit breaker. I've heard of 5 and 7.5a fuses in theis ckt. onmy NH 7610s, i went with a 10aFA fuse for my igntion/safety cutout and have had no more problems. even at 10a/SB rating.. your wiring is/would be protected...
Problems arise the most when the battery is a bit older .. or the weather is cold.. or there are some bad connections.. anything that drops the voltage a bit .. which makes it pull more current.. etc..
soundguy
