planter plates; update on topic 138453
Lew Best
03-17-2008 16:58:42
Never could find a model number for the planter I have but the seed hoppers, etc. are good. No way to adjust planting rate without disassembling it & putting different sprockets on it. Also, no press wheels (but has wheels mounted between the planter units to drive the boxes).
Found a 246 JD on ebay for cheap that needs the seed hoppers so between the 2 I should be set. I'm picking it up later this week. I had a 246 before & recall it was adjustable by changing sprockets without removing them.
So, what plates do I need for the Reid yellow dent? I'd like to plant around 12-18"; know that's probably wider spacing than most folks use but I'm "trying something." Seed company said they were just graded as "flat seed"; not by size.
BTW anyone have a manual for the 246 planter you'd sell or sell me a copy of (PDF by email would be fine).
Thanks!
Lew near Waco, TX
Lew Best
03-18-2008 15:59:37
 Re: planter plates; update on topic 138453 in reply to larryh, 03-18-2008 15:55:16
Thanks! I'll give you a call. Where are you located?
Lew
junior neff
03-18-2008 04:00:56
 Re: planter plates; update on topic 138453 in reply to Lew Best, 03-17-2008 16:58:42
may be this link will help, they have plates and blank ones that you can make yourself. Lincoln Ag Products
