disc bearing inserts
Pandora 504
03-16-2008 16:25:41
Fixing up an old King disc,has 11/8 square axles,several broken blade and 6 bad axle bearings. What is the trick in getting the bearing inserts out of thecast iron pillow blocks??? I know that they are supposed to swivel to a 90 degree angle to the holder and come out somehow,there is a slot on top and bottom of one side of the pillow block.Probaly real simple once you see it done one time. Any help would be great help. Thanks,Butch
JMS/.MN
03-16-2008 16:39:19
 Re: disc bearing inserts in reply to Pandora 504, 03-16-2008 16:25:41
You"re on the right path. You understand the concept. Put the unit in a vise, stick a shaft through the bearing and pivot it 90 degrees. Then rotate it until it gets to the slots you talk about. Should tap right out.
Pandora 504
03-18-2008 09:26:02
 Re: disc bearing inserts in reply to JMS/.MN, 03-16-2008 16:39:19
Thanks for the help,took a little heat and a lot of PB Blaster but got them all out,very rusty from years of neglect, disc should have easier life now, Butch
