levee disc
larry cook
03-16-2008 06:51:50
bidding on a levee disc, government auction in corpus christi. it appears to be a 6 footer. has 8 blades on each row, blades are notched type. appears to be in very good condition. what is this disc worth? currently i have a bid of $240.00 on it.
larry cook
johns48jdb
03-17-2008 14:09:47
 Re: levee disc in reply to larry cook, 03-16-2008 06:51:50
is the axle completely straight that the 8 blades are mounted on and is the rear gang set at an angle to the front gang. if the blades all touch the ground at the same time just setting thereits just a regular disk. terrace plows have the blades set at an angle to the ground where they face each other and between the four blades on each side they make a mound of dirt. i'm just confused about what you mean at an angle.
larry cook
03-17-2008 15:15:58
 Re: levee disc in reply to johns48jdb, 03-17-2008 14:09:47
just a regular disc, the axle is straight. sorry for the confusion.
thanks
larry cook
johns48jdb
03-17-2008 08:08:43
is the disk turned at an angle to the ground or are the axles straight. you may be looking at what we call a new ground disk if the blades are real big and on a straight axle.
larry cook
03-17-2008 09:08:26
 Re: levee disc in reply to johns48jdb, 03-17-2008 08:08:43
it's a tandem disk, the disks are at an angle. i got alot of feedback on the ford site and i think i will get it if the price is right. still @$240 right now, maybe it will not get above 5-600.
larry cook
larry cook
03-17-2008 09:08:19
larry cook
usetob
03-16-2008 16:27:33
i THINK YOUR LOOKING AT A TERRACE DISC, i FARMED RICE ALL MY LIFE AND HAVE NEVER SEEN A 8 BLADED LEVEE PLOW
