left hand no 20 chilled plow
Terry Mizer
03-14-2008 16:58:10
Does any body know any thing about a left hand plow I have one it is the only one i have seen
johns48jdb
03-15-2008 07:29:28
 Re: left hand no 20 chilled plow in reply to Terry Mizer, 03-14-2008 16:58:10
i'm in n al and those plows were common around here. is the 20 a chattanogga or oliver plow. i've only seen one ih mule drawn plow around here. avery and oliver were the favorite from what i've been told. have you ever seen a hill side plow. you broke around the hill and when you got to the other end you tripped a lever and used the old mule to turn it over with and then you went right back down the same furrow you just plowed. some turning plows have a bracket on the side of the handle. i just found out that you laid the plow over on its side on that bracket and let it drag along the ground when going from one field to the next. i don't know if that answers your question or not, while not common left handed plows are not something special.
