JD # 5 Sickle Mower
Stan (Mo)
04-17-2000 18:35:50
I recently obtained what I believe is a JD model 5
sickle mower. On the drive housing (which houses the chain drive) I can find only one
fill plug, about half way up the housing. Do I fill this to the top, or is there another drain/fill plug??? Also, what weight lube should I use. Thanks Stan.
Sam Moore
04-18-2000 10:39:32
 Re: JD # 5 Sickle Mower in reply to Stan (Mo), 04-17-2000 18:35:50
Fill it to the level of the plug you mentioned. I use 85W90 gear oil in mine.
Sam Moore
04-19-2000 07:19:50
 Re: Re: JD # 5 Sickle Mower in reply to Sam Moore, 04-18-2000 10:39:32
Sorry, but the old memory is failing me. I just ran across my No.5 Mower manual, which says that SAE140 gear oil should be used in the gear box.
stan (MO)
04-19-2000 20:43:50
 Re: Re: Re: JD # 5 Sickle Mower in reply to Sam Moore, 04-19-2000 07:19:50
THANKS SAM,
I can relate to the memory thing.
Randy Stanley
