Mower PTO Shaft
HAS
03-11-2008 18:06:41
I just aquired a Corsicana drag behind 4' mower to pull behind my Farmall A. The tractor end PTO shaft has a triangular profile tube but the mower shaft is rectangular - 1" X 1 1/8" as far as I can measure. The profile tube is rusted inside and I can't get it to slip on the mower shaft more than a couple inches. Is the rust my problem or did they give me a mis-match on the tractor end shaft?
JMS/.MN
03-12-2008 07:50:24
 Re: Mower PTO Shaft in reply to HAS, 03-11-2008 18:06:41
Take it to a welding shop that has the square stock and match to the size you need. Cut the good yoke off and reuse it on the new square stock.
johns48jdb
03-12-2008 04:43:25
i think your in for a big surprise. you need to carry the pieces with you and compare them to what they have available. one half may be more expensive than the other. check the condition of the u-joints to see if they are in good shape while you've got them off. most people call what your doing bush hogging. the term you used threw me at first. i hope you have an over running clutch on the tractors your using that don't have live pto's on them. you need that for safety sake.
HAS
03-12-2008 05:42:56
 Re: Mower PTO Shaft in reply to johns48jdb, 03-12-2008 04:43:25
The U-joints n both ends are in good shape. Do you agree that I have different halfs of two different shafts? Has anyone ever seen a square shaft go in a triangular hole?
johns48jdb
03-13-2008 19:51:30
 Re: Mower PTO Shaft in reply to HAS, 03-12-2008 05:42:56
yes. you have two different halves.
jose bagge
03-11-2008 18:43:28
sounds like you got two halves of different shafts....you got shafted!
HAS
03-11-2008 18:50:31
 Re: Mower PTO Shaft in reply to jose bagge, 03-11-2008 18:43:28
Oh well, I guess it's nothing that a few bucks at TSC won't take care of.
