john deere model k manure spreader
Shawn in NE
03-10-2008 11:02:17
I have a J.D. model K manure spreader that i am looking for a part for. Its a pillar block on the rear shaft on the bed chain. If anyone would have one or would know of where i could get one, could you please let me know? Thanks
Mike in Iowa
03-26-2008 17:31:39
 Re: john deere model k manure spreader in reply to Shawn in NE, 03-10-2008 11:02:17
Shawn:
Let me know what town you are from.
I am in western NE about once a year (Valentine to Chadron area)and may be able to bring it to that point. If I could find a piece to haul home it would make it a better deal. What do you have to trade?
Mike
Shawn in NE
04-20-2008 07:36:29
 Re: john deere model k manure spreader in reply to Mike in Iowa, 03-26-2008 17:31:39
Mike, dont know if you got my last message. Was still wondering if your interested in trading for something on your model k manure spreader. Let me know what your looking for. Thanks
Shawn in NE
03-26-2008 18:34:34
Mike, Im in the little town called Arthur, which is about 2 1/2 hours south of Valentine and about the same from Chadron. But if you get out this way, ill figure out a way to make it work. Will meet you somewhere. What are you looking for to trade?
Mike in Iowa
03-11-2008 15:57:21
Shawn: Where are you in NE?
I have a model K JD spreader that I would be willing to sell for parts. All of the mechanisms work but I would like to keep the rear wheels for another project.
Let me know and I can send pictures if you are interested.
Thanks!!
Mike
Shawn in NE
03-13-2008 19:21:00
 Re: john deere model k manure spreader in reply to Mike in Iowa, 03-11-2008 15:57:21
Mike in Iowa, I wouldnt mind having the whole thing but the axle, but im in the western part of the state and this time of year its hard for me to get away. As it is calving season here. So needless to say that im a little busy right now. But if you would be to take off the whole conveyer shaft including the rachet drive I would sure be interested. i would make it worth your time and would pay for shipping too.
Spritzer
03-11-2008 07:54:28
Is it worn out, or broken? If worn out, have it lathe-turned to insert a heavy bronze bushing internally--drive fitted. Then reamed to fit the shaft.
Shawn in NE
03-11-2008 09:06:18
 Re: john deere model k manure spreader in reply to Spritzer, 03-11-2008 07:54:28
the pillar block is broken, and its really not even a pillar block, i dont really know what you would call it because there is no bearing. All it does is hold the shaft in place.It would be an easy fix if it was steel, but it is cast and cant be welded
Spritzer
03-11-2008 16:13:14
 Re: john deere model k manure spreader in reply to Shawn in NE, 03-11-2008 09:06:18
But doesn't that "pillow block" that is broken support the shaft-and-sprocket that advances the apron? I don't have a JD spreader, but I've had several other brands- -None of them have had "bearings" as such, but the cast "PB" IS the bearing. If you have all the broken pieces, the cast CAN be brazed by an accomplished welder. Another option might be to get a salvaged one. I have an IH PB, but it might be totally different- - - Martin
tg in VA
03-11-2008 04:21:38
Try a local bearing supply company. Most areas have companies like this that supply bearings to local industry. I have even purchased apron links from our local bearing supplier (and they were stock items).
