plows for super a
xj43
03-09-2008 11:09:54
I just finished restoring a farmall super a. I going to use it for garden. I've had small garden but looking to expand. Was wanting to know what plow or plows would work best for small garden. I dont't have any rear attacments so i'm converting the rear lift to 3 pt. I have 6 straight shank cutivating plows for the belly lift system. thanks for any advice
Reddog
03-09-2008 19:01:37
 Re: plows for super a in reply to xj43, 03-09-2008 11:09:54
The single bottom plow for a Super A I believe is a A-193. Hugh is correct it takes a little while to put on, but it will plow like a dream.
If you want send me an e-amil and I will send you pictures of a A-193 installed on a Super A.
Mike
[email protected]
Hugh MacKay
03-09-2008 11:39:06
xj43: If your converting the tractor to 3 point hitch then your best bet would be find a single bottom 3 point hitch plow, any make in good shape. Super A factory plows are fine, however it's roughly a 2 hour job to mount the plow, even longer if you have a 3 point hitch on there, as it will all have to come off before you mount the plow.
