Home built sprayer for acerage
John in NE
03-05-2008 15:09:47
Hello all, I was wondering if anyone has experience with building a sprayer from scratch. I have a HydroCorp Roller pump, a 200 gallon plastic tank , and acess to various teejet sizes. Would be running this on a 2n tractor PTO, for an 8 acre plot. Is this a good idea or should I just buy an ATV sprayer? Thanks
Ron in AR
03-06-2008 17:32:50
 Re: Home built sprayer for acerage in reply to John in NE, 03-05-2008 15:09:47
I built my own sprayer for 125 acres. It has two 125 gallon tanks on it, plumbed together (or can be used seperate with the valves I have in place). It has a 20 foot folding boom that is height adjustable. The whole thing sits on a four wheeled steering trailer like a small hay wagon running gear. I scrounged a lot of the parts and bought the nozzles, pump, and hoses. I figure I have a total of about $500.00 cash money in it. Well worth the effort as far as I'm concerned.
Andy Moncman
03-06-2008 16:09:53
I built my own using a Hypro 6 roller pump, a 55 gallon plastic drum and teejet spray nozzles, rubber hoses for the plumbing. Looked over the commercial units at tsc to get the idea of how thing go together.I've used it on my Ferguson TEA 2085 makes the front end a little light but with a little caution I can do all my spaying including the hills on my property. Its dark out now I'll try post a photo tomorrow.
Dave Sherburne NY
03-06-2008 12:09:25
When I was spraying commercially 10 years ago we
used 12 gallons per acre 8 acres= 96 gallons you would have to fill a 55 gallon drum twice. When
my father in law was farming his sprayer was homemade with a 55 gallon barrel. I think your tractor would handle that.
JMS/.MN
03-05-2008 22:04:38
Home made or commercial does not matter. 200 gallon tank equals 1600 pound + mix.- too heavy for a Ford 2N. Just don"t fill it. Pump issue- roller pump- what type of rollers? Some do not handle certain herbicides. Plastic, rubber, viton,? You need to know that. Diagrams?- What Gerald said, or Spraying systems company.
old
03-05-2008 15:39:15
Funny how you asked that. We just got one last week at an auction that is home made. Needs some work but it should be up and working by spring. So yes it can be and has been done before
John in NE
03-05-2008 16:46:10
 Re: Home built sprayer for acerage in reply to old, 03-05-2008 15:39:15
Thanks for the replies guys... So does anyone know of a source for a hose/pump/regulator diagram, basicaly a safe and effective way to plumb it? Thanks again for the quick replies
Gerald J.
03-05-2008 16:54:43
 Re: Home built sprayer for acerage in reply to John in NE, 03-05-2008 16:46:10
TeeJet catalog #50A is a good one. Has all the parts you'll ever need and all the plumbing details.
I have troubles with a 65 gallon three point sprayer on my MF-135 and its twice as heavy as a 2N. A 200 gallon tank filled will weigh nearly as much as a 2N (1600 pounds). That won't fit on the 2N 3 point. It will have to be on its own axle as a trailed sprayer.
You have plenty of a pump too. I use a 4.5 gpm 12 volt electric pump for field spraying 4 to 8 rows at a time just fine.
Look at the air injected turbo teejet nozzles for really controlled spraying that tolerates wind.
Gerald J.
John in NE
03-05-2008 19:01:04
 Re: Home built sprayer for acerage in reply to Gerald J., 03-05-2008 16:54:43
Thanks a lot for the information, I may try to find a smaller tank, if not, definately use the axle idea. Take care
Dachshund
03-05-2008 15:25:45
Wouldn't take much to put an axle and a tongue under what ya got.....
John51
03-05-2008 15:21:18
I'd build my own just because I would want to. But a 2N??? I use a 200 gallon tank on a 4020 with 4 front weights and I have to watch the front end when starting out. Just the empty tank and booms might be too much for the 2N.
paul
03-06-2008 00:38:34
 Re: Home built sprayer for acerage in reply to John51, 03-05-2008 15:21:18
A 960 with wide front gets light up front with a 100 gal tank full.
N would have be less than that.
--->Paul
dwrk
03-06-2008 16:38:43
 Re: Home built sprayer for acerage in reply to paul, 03-06-2008 00:38:34
Heck I had a 200 gallon Hardi on an MFWD JD 7510 before I bought the trailed sprayer, it would lift the front end up on it if I wasn't REALLY light on the clutch.
