two rims to make one good one w/ pictures
Sandknob
03-03-2008 18:57:26
Please don't kick me off for doing this to an old AC rim, but hopefully this works out as planned!!
I have an International Little Genius 2-14 plow on rubber that I am working on restoring. Well I have been trying to find a good front rim and a good rear rim for a couple of years now and found it to be next to impossible (they are either rotten or $$$$$$$). So I purchased a spare plow for $40 took all the parts off I needed and sold the rest for scrap and got $45. I saved both front rims, and the back rim as well as a couple of needed levers. Front rims were getting pretty bad though, so I decided to make one good rim using two bad ones. I had a bad WD front rim (bolt holes wallored out), so I cut the center out of it and cut the rim off of the center on the old plow wheel and after a little work I will be able to take it to the welding shop for final welding. Then it will be primed, primed, primed/surfaced, painted, painted, and clearcoated so as to make it last for a long, long time. Just thought that I'd share some picks of what it takes to do this.
Thanks
Adam
third party image
third party image
third party image
JMS/.MN
03-03-2008 22:55:59
 Re: two rims to make one good one w/ pictures in reply to Sandknob, 03-03-2008 18:57:26
Not a problem- been doing that for years. Pick up old rims at auctions- don"t care if the centers are gone or the rims. Can get either for a buck or so. Drill out the welds, whack the centers with a bfh, and keep either good part. Weld two good ones together- cost is minimal, good winter shop project. New rims were 30, now up to 100 bucks. Recycling 101!
RayP(MI)
03-05-2008 18:21:12
 Re: two rims to make one good one w/ pictures in reply to JMS/.MN, 03-03-2008 22:55:59
Friend of mine used to make wide rims for dune buggies by cutting and welding rims together. Stretching the tire to fit those wide rims was the problem!
2x4
03-04-2008 20:36:00
guilty here also. For implements I have ground out a rusted section of rim, then cut that size section from another old rim & weld it in. Body putty can fix the looks of it. Saved several rims this way. Wouldn't do it for high speed usage tho.
