NH 33 Chopper
gerald33
03-02-2008 23:56:01
have an old NH 33 crop chopper i use to clip pasture need to replace some bearings does any one know how to remove the shaft that goes through the chopper and fan wheel have parts book but not much help
Fordfarmer
03-03-2008 06:30:44
 Re: NH 33 Chopper in reply to gerald33, 03-02-2008 23:56:01
On the gearbox side, right? It's not fun. Unbolt the shields and gearbox and slide the over-running clutch apart. Take the belts off, then the upper pulley. Then you can get at the bearing housing, but it seems like I had to get the flywheel loose from teh shaft, too. There's a set screw (bolt) for that (and maybe a key? been a couple years, can't remember for sure), and hope there isn't too much rust. Or I could sell you my 36 if you arent' too far away. :)
gerald33
03-03-2008 08:22:44
 Re: NH 33 Chopper in reply to Fordfarmer, 03-03-2008 06:30:44
thanks ford farmer ihave done as you suggested fan wheel is free i guess my question is from which side does the shaft scome out it appears to me that it has to be driven out from the belt pulley but that does not make to much sense if the pulley were all that needed to be replaced the it seems the shaft should go toward the flail side
Fordfarmer
03-03-2008 15:23:36
 Re: NH 33 Chopper in reply to gerald33, 03-03-2008 08:22:44
If I remember right, it comes out the pulley side. I'm pretty sure thats how I pulled mine anyway. It's been awhile though... it MIGHT be able to go out the flail side, but that will require at least taking the bearing grease cap off the flail side. As far as making sense... remember... an engineer who will never have to work on it designed it, not a mechanic or farmer.
