JD 7000 Series Planter
Marcus
03-02-2008 06:43:58
How much hp would I need to pull a 4 row 7000 planter set up for no-till, with fertilizer,on flat to gently rolling ground? Thanks
paul
03-02-2008 09:59:01
 Re: JD 7000 Series Planter in reply to Marcus, 03-02-2008 06:43:58
I've done it with a 27 hp tractor, but did not set any speed records. This was my best year of corn ever! Guess we all try to go too fast....
40 hp would probably be great, you need good hyd output to lift it. I have a couple old 40 hp tractors I would like to use, but their 1500lb hyd systems don't pick it up when full of fert & seed.
--->Paul
Gerald J.
03-02-2008 07:53:56
third party image
I planted last year with no till conditions, but with the liquid fertilizer riding on the tractor three point with my MF-135. At no time did the tractor work hard, it was running at a fast idle all the time. It was a lot easier on the tractor than planting 6 row narrow with an IH Cyclo 400 years ago.
I needed more front weight on the tractor, could only put half a tank of 32% on and still steer with the front wheels.
Gerald J.
Marcus
03-02-2008 09:54:43
 Re: JD 7000 Series Planter in reply to Gerald J., 03-02-2008 07:53:56
Thanks all to who responded.I have JD 1020 diesel and it is rated at 39 hp if i,m not mistaken. Thanks again
Eric in IL
03-02-2008 06:59:22
I"d say 40 HP in good moisture conditions and 50 HP for the wet spots.
bradk
03-02-2008 06:54:09
I'd say around 30-35.
