Corsicana Brush Hog
HAS
03-01-2008 18:27:50
I just bought a 4' Corsicana Brush hog Model 48E.
It has a 1/2" pipe plug in the top of the gear housing to fill it with oil and a 1/4" pipe plug about center at the back of the gear housing. Is the 1/4" hole the fill level? Or do you fill it on up?
What weight of oil should I use in this gearbox?
HAS
03-03-2008 09:44:21
 Re: Corsicana Brush Hog in reply to HAS, 03-01-2008 18:27:50
Thanks Fellas,
That helps alot. Mine has no grease fitting and I'll use 90 wt gear oil.
tractormiallis
03-02-2008 10:49:55
I have one made for AC snap coupler that is a 5 foot that has a grease fitting for the gear box. It only takes grease, no oil.
BCnT
03-01-2008 19:02:23
you got the fill and level holes correct...i always run straight 90 weight in my shredders.
Ultradog MN
03-01-2008 19:00:13
The gearbox needs room for heat and expansion.
Fill it to the lower hole.
I use regular 80W90 in mine.
