How to replace axle bearing on New Holland 55 Rake
reid5365
02-29-2008 20:10:09
Just as title says. How would I go about replacing the axle bearing on the right side of the rake if your looking at it from the back?? Thanks guys
reid5365
03-01-2008 11:38:00
 Re: How to replace axle bearing on New Holland 55 Rake in reply to reid5365, 02-29-2008 20:10:09
Sorry guys I thought the previous owner had said the axle bearing was out. I guess its a bushing. Why would I need to replace the axle if the bushing is worn. It is just one on the right side.
Ultradog MN
03-01-2008 19:13:54
 Re: How to replace axle bearing on New Holland 55 Rake in reply to reid5365, 03-01-2008 11:38:00
I'm not familiar with your rake.
But on bushings in general they often wear out larger than their diameter so the shaft wears into the cast or steel that surrounds the bushing.
That eats up the shaft too and makes replacing bushings pointless.
The other posters were merely giving you a heads up for what might likely be an axle replacement too.
If I read their posts correctly it is a straight shaft from one side to the other and a piece of cold rolled from your local steel yard/machine shop is cheaper than one from NH.
Good luck
paul
03-02-2008 10:02:18
 Re: How to replace axle bearing on New Holland 55 Rake in reply to Ultradog MN, 03-01-2008 19:13:54
I asked once & thought the 55 didn't even have bushings to replace. One of mine is starting to wobbly.
--->Paul
ohio dick
02-29-2008 21:54:23
the 55 has bushings. They drive out less than 15.00 dollars each it takes 4. A new axle from CNH. is 258.00 machine shop will make one for 80.00
banjo
02-29-2008 21:07:49
they dont have bearings. it has a bushing. if it is worn the axle is probly worn also.I think you can get the bushings at case/new holland dealer.
