MF #10 baler sprocket broken on pickup auger
Darin IN
02-29-2008 08:18:50
A friend had broken the drive sprocket on the pickup on his baler. It had been brazed by the last owner, but there was a piece lost this time, so it can't be put back together. The # on the sprocket is 152672M2. Does anyone have or know of a baler that's being parted? I've been calling around, but have only found a pricey new one.
Darin IN
02-29-2008 18:51:23
 Re: MF #10 baler sprocket broken on pickup auger in reply to Darin IN, 02-29-2008 08:18:50
Thanks for the info. Id been looking for a weld on double, but hadnt thought of the single.
NBAllen
02-29-2008 10:01:45
If you don't care about originality, you may be able to replace it with a universal weld-hub and sprocket. If the chain is "double-pitch" you can replace a "double-pitch" sprocket with a common "single-pitch" sprocket.
My neighbor and I did that on this NI spreader after the sprocket finally gave way when I started to unload my second load of the day. :-(
Check around - I think it was ~$45 for the hub and sprocket, + 10 minutes to weld the two together.
Nathaniel
Third Party Image
