sawdust
plowboy1
02-26-2008 19:41:09
Does anyone know of a mid size machine for grinding up scrap wood to make sawdust? The stuff is near impossible to get "round here. Thanks for the help.
RayP(MI)
03-02-2008 16:48:30
 Re: sawdust in reply to plowboy1, 02-26-2008 19:41:09
My favorite sawmill cut me off on the free sawdust. Seems they have a buyer who pays a few dollars a truckload and makes wood pellets out of it for pellet stoves.
mark
02-28-2008 11:48:49
are there no pallet mills near you? they will USUALLY give it to you to get rid of it. The local mill here has a mountain of it, you shovel for free or they use a Payloader for $5 a pickup load....best 5 bucks I ever spent!
plowboy1
02-27-2008 18:47:10
Wow, they give it away? you guys don't know how good you got it! I'm in Mass.. Been delivering sawdust to dairys and a few stables for like 20 years. Back then, I had maybe10-12 dairys, now I got 2. Then, it cost me 5-10$ to fill 17yard truck and I got $90 to deliver. Now, if I can get it, the mills are charging $100-130 aload! Oh ya, I getabout $95 to deliver! Where did I go wrong? Thanks for your help, I will check out TSC but I imagine it's a home owners machine.
BC in TN
02-27-2008 17:42:05
Hard to get?
My neighbor handles 2-4 semi truckloads of the stuff each day here in Middle TN.
He'll be glad to sell you a truckload or 40 loads - where/when do you want it delivered?
bellyacre
02-27-2008 09:42:12
Don't know how much you want to do. Neighbor uses a tub grinder , for scrap from cabinet factory and rafter plant. Uses it for cattle bedding. Also grinds used newspaper from recyclers
msb
02-27-2008 08:53:38
TSC Stores sell it.
newbie haymaker
02-27-2008 08:32:43
What are you going to use it for? If you are going to use it for horses make sure not to use any dust or chips contaning walnut. I make the best shavings using my planer or shaper. if you have limbs or logs, cut a piece of plywood to fit through your planer and screw log to it from the bottom until you get a god flat spot on top. Then unscrew and turn over and have at it.
fergienewbee
02-27-2008 06:05:59
Be careful burning sawdust. I threw some on a fire from cleaning my garage and singed my eyebrows. The stuff is like grain dust.
Larry
Tony W
02-27-2008 05:42:39
You may ask the local grade/high school wood shop if they have one. If you are lucky to have a wood mill cutting logs, they give that away here.
Larry in GA.
02-27-2008 02:59:22
Any cabinet shop should be able to help Around here they burn it a couple times a week at most shops. Larry
John S-B
02-26-2008 21:14:54
Where are you at Plowboy? And What kind of sawdust are you looking for? I just filled a bag in my dust collector if you're close to Central Oh. A planer, jointer or table saw with dust collection ports would be the easiest way to get sawdust.
