JD planter plates
mwilke
02-24-2008 08:15:03
I have a model 246 John Deere planter. I have some of the older corn and bean seed plates. On EBAY I am seeing "Lustran" plates with different numbers. How are these plates different from the ones I currently have? And, if interchangeable is there a conversion chart for comparing the part numbers to the older JD part numbers in the operators manual for the planter.
Thanks
johns48jdb
02-25-2008 05:29:07
 Re: JD planter plates in reply to mwilke, 02-24-2008 08:15:03
i don't think the drive system is the same between plastic and metal plates for the older jd planters. the 246 plates will fit all the way back to single row mule drawn planters. i have a pile of them and would sell you some right if i knew a number to look for.
phillip d
02-24-2008 09:18:07
I rent our neighbours 1340 JD.It uses Lustran plastic plates.I always go by the plate recomendations on the seed bag for plates.
Goucho
02-24-2008 08:59:39
Contact Lincoln Ag Products they make those plates.
ktheo1
02-24-2008 08:37:25
Lustran plates were the plastic plates .As far as converting to steel plate #'s I don't know .I usually try to match the seed to the plate . The thing I run into is what they call Medium flats now are much smaller than the med. flat plates .I think all the seed sizes are smaller than the plates called for to plant them .If you don't watch it you get way to much population.
mwilke
02-24-2008 08:54:58
 Re: JD planter plates in reply to ktheo1, 02-24-2008 08:37:25
Thanks for the response. I'll keep that population thing in mind.
