plow points ford plow 10-152
gary belote
02-18-2008 11:15:56
points/shares for this plow discontinued by ford.
need 2-12 inch 2 hole shares. anyone with suggestions please let me know.
Leroy
02-19-2008 05:34:25
 Re: plow points ford plow 10-152 in reply to gary belote, 02-18-2008 11:15:56
Is this a blacksmith sharpen type share, I know that is a 2 bolt share. The blade type I do not know about. If it is a blacksmith sharpen type share the same share was used on the Ferguson plows as well, but as the bottoms were made different than the 14" bottoms the 14" share cannot be used even with modification. Now if a blade type share they all have the same angle to the point and same width the length of the share so any blade type can be shortened to fit a smaller bottom plow by cutting of the back end and if nessary puting in different holes.
Murn Ga
02-18-2008 12:10:20
I know for a fact that the 14" shares are available because we stock them where I work. Just pick up a couple from your N.H dealer and cut a few inches off the rear end and you will have the same thing. Easy to cut in a band saw or a torch should be fine. 251421DS is the N.H. part number,105205 is the old Ford number.
