hyd. Valve
sam in mo
02-18-2008 05:32:54
Looking for some info. on a hyd. control valve. It has four positions. The furthest to the rear is netural. The next forward position is right cyc. then the next pos. is both cycs. then you have to move the lever to the left 3/8 inch and move forward all the way and it is in the left cyc. position only. It has a total of six ports for hyd. hoses. Does anyone have any idea as to what this could be used for? No other markings on the valve
sam in mo
02-18-2008 16:36:52
 Re: hyd. Valve in reply to sam in mo, 02-18-2008 05:32:54
Wire brushed the dust off and it has a casting # 474352. Maybe this will help.
J Schwiebert
02-18-2008 05:39:27
Well it should have 6 ports. Is there a casting number. Am I correct that there are two spools or is there one controller that moves two spools> How about a picture?
sam in mo
02-18-2008 05:49:32
 Re: hyd. Valve in reply to J Schwiebert, 02-18-2008 05:39:27
Dont have camera. there is only one lever. the patter is like a capital L with a leg straight down off of the right side of the L. Thanks for the reply. Sam
sam in mo
02-18-2008 06:04:47
 Re: hyd. Valve in reply to sam in mo, 02-18-2008 05:49:32
I should add that it was fairly dark in the shed with no ele. and the valve was fairly dirty from sitting on the shelf. There is pipe plugs in all of the outlets. I will check today and see if there is any numbers on it. I will know more later in the day. Thanks Sam
