Coolant drain plugs on JD B
mul-skiner
02-18-2008 05:11:28
Could someone tell me for sure how many coolant drain pugs there are on a 1949 John Deere B? Thank You.
johns48jdb
02-21-2008 11:17:02
 Re: Coolant drain plugs on JD B in reply to mul-skiner, 02-18-2008 05:11:28
simple test remove the oil drain plug or crack it open to see what comes out. some water is to be expected from condesation if its been settting long, but pour water in it and remove the plug and come back in a hour or so (if it takes it that long) and see what it looks like then. if your water level is down or running out the oil drain plug then somebody has a problemn. my first cousins son just found out the tubes that the two inside push rods run in through the head had holes in them and water was pouring through into the block and oil pan. ;uckly her never cranked it up.
Leroy
02-18-2008 05:57:22
I put a complete reply on to your other post on tractor talk. The answer is maybe-maybe NOT, depends on if tractor has an after market water pump, then the pump also has to drain.
mul-skiner
02-18-2008 06:32:18
 Re: Coolant drain plugs on JD B in reply to Leroy, 02-18-2008 05:57:22
Thanks,Leroy I missed your post. I have my eye on one the tractor does not start water has been drained just leery about that I was fooled once before about water being drained guy said water was drained pulled one plug not two, well in minnesota you know the rest of the story.Thanks again Ill take another look at it it looks original.
J Schwiebert
02-18-2008 05:41:04
We have 3 model B tractors and they all have one drain port in the bottom of the cylinder head. Has a water pump been added to your B?
mul-skiner
02-18-2008 06:35:46
 Re: Coolant drain plugs on JD B in reply to J Schwiebert, 02-18-2008 05:41:04
I'm just tire kicking it now just maybe being overcautious it's not being given away if you know what I mean.
