Disk Make/Model
MRN
02-17-2008 15:17:37
third party image
I'm hoping that someone will be able to identify the disk in the photo (it's about 12' or so wide) and tell me where to get bearings for it. Any ideas on what they will cost?
David in Missouri
02-20-2008 09:54:51
 Re: Disk Make/Model in reply to MRN, 02-17-2008 15:17:37
I rebuilt my disc last winter..... .got all the bearings/parts cheap at www.AgriSupply.com.....I think the 1" square shaft bearing halves were about 4 bucks each, and the spacers were about the same.
Animal
02-17-2008 20:17:44
I get disc bearings ditch witch and other from IBT in Kansas City
RodInNS
02-17-2008 19:26:58
Dunno. Could be a Case... Doesn't really matter. It's a disc. Bearing shop will get the rolling stock for you, no problem. I'd guess about 30 bucks a pop, but you never know. Shoup or any number of other aftermarket sources could probably get them too. Just get the bearing numbers or measure it up with a digital caliper... Race OD, width and shaft OD is all you should need.
Rod
MRN
02-17-2008 18:23:09
Thanks guys!
awhtx
02-17-2008 18:09:52
I got bearings for my MF wheel disc at Tractor Supply for $8 or $10 less than any other place I checked.
Robert Bedford
02-17-2008 17:02:46
IT is a case wheel disc. Bearings are avalable from napa, caseih almost any where.
JMS/.MN
02-17-2008 16:57:40
Try www.schoupparts.com
Tim(nj)
02-18-2008 16:31:36
 Re: Disk Make/Model in reply to JMS/.MN, 02-17-2008 16:57:40
darn minniesootan, keeps puttin" that c in there :)
www.shoupparts.com
Farmallb
02-17-2008 16:55:14
 Re: Disk Make/Model in reply to Texasmark, 02-17-2008 15:17:37
Looks JD with a orange primer, or NI if they made discs, and/or Kewannee
