NEW HOLAND HAY WAGON
Jed in IN
02-14-2008 20:21:22
I WAS WONDERING, TO USE ONE OF THESE WAGONS DO YOU HAVE TO HAVE A WIRE TIE BALER OR WOULD MY STRING TIE JD 328 WORK ?,THANK YOU
joe e-tx
02-15-2008 17:52:55
 Re: NEW HOLAND HAY WAGON in reply to Jed in IN, 02-14-2008 20:21:22
as long as it a square bale some were between 14 or 18 inches and 32 and 40 inches long a NH stachliner will pick it up as long as ins on its side
superman66
02-15-2008 06:43:57
Jed: Try this site for info on N H Stackliners. Superman66
paul
02-14-2008 23:07:08
No wire tie balers anywhere around here, lots of NH bale wagons.
Uniform bales is what's needed.
--->Paul
AtlasHayCo
02-14-2008 22:45:53
The manuals state what is exactly needed.
From what I know you just need sharp bale knives, and square/square bales. I know that they have to be a certain length. If some of the hay is inconsistant (because of tractor speeds/windrow thickness) the stacks could tip over from a "limp noodle" towards the bottom.
Even bales make that deal work right. Twine is the Way!
onefarmer
02-14-2008 20:32:33
If your talking about the automatic balewagon normal string works just fine. Just need a solid bale, no limp noodles.
