JD Van Brunt Grain Drill Planting corn???
reid5365
02-12-2008 14:34:34
Could you plant corn with a JD Van Brunt 17 Hole Grain Drill??? If so how would you go about that?? Thank You
flying belgian
02-13-2008 15:19:13
 Re: JD Van Brunt Grain Drill Planting corn??? in reply to reid5365, 02-12-2008 14:34:34
I used to have one and I think on the seed rate chart under box cover it told how to use it to plant corn.
James22
02-13-2008 09:37:36
Yes it can be done, but I would do it for grain production unless it was small acres and merely a hobby. My neighbor use my old IH MF drill, plugged the extra openers so he had 28 inch rows and planted a food plot. It worked OK. A double run feed is better than fluted feed; less grain damage and more precise seeding although not near what a planter will give. Newer drills can have depth control wheels on the opening disks which would help with seed placement, but I doubt you have this on your drill. Try to work the ground around 2 inches deep so that the seed depth placement will be in the ball park of being correct. My old drill had markers but as was stated you can cobble something together which will work. I wouldn't really worry about it that much unless you are going to cultivate and it is not a food plot. Don't agree with the negative comments about the IH 400. I raised 200 bu/acre corn on timber soil using it. The JD finger is a good planter, but too many moving parts for my liking which need to be kept in adjustment for the best results. I've seen plots where a later model CIH cyclo planter gave better spacing than a mediocre adjusted JD finger planter. The 400 has been replaced with a 900 and after I made a few initial modifications to improve spacing, it is good to go "forever".
J Schwiebert
02-13-2008 04:19:52
If you are going to try this use duct tape to plug off the opener pockets. We do this on a 750 drill for two spacings so we can spray beans.
JMS/.MN
02-12-2008 21:49:06
Yes. You can plant it. Like paul refers to- what is the final product- food plot or a real crop? Grain drill is called a grain drill because of what it is designed to seed- grain. Oats, barley, rye, wheat, etc. Grain drills have very poor depth control, and that control is necessary if you are planting corn. For a food plot- determine the row spacing you want, cover the in-between openings in the seed box, and adjust the fluted openers to shell out the seed.
TomTex
02-12-2008 21:09:26
You can still get an Operator Manual from JD, and it tells you exactly how to do it. Tom
paul
02-12-2008 19:16:15
If you are looking for good yield & making some money, a drill does a very poor job of planting corn.
If you are putting in feed plots for the deer to run over, it will work fine.
Duct tape over several of the seed opennings, run it real slow. You only want 18-34,000 seeds per acre, that will be the hard part, to do the math & get that low of a rate.
For good yield, corn needs to be a very accurate depth & evenly spaced in the row - things a drill cannot do.
--->Paul
Gerald J.
02-12-2008 15:50:16
I did that once, back about 1992. It worked. I hinged some 2x6 to each end of the rear platform and mounted a cultivator shovel on edge to make a marker. I used cable to the front corner of the planter to slow the ripping off of hinges and planks. I lowered and raised the markers manually by getting off the tractor.
To plant 35" rows, I cut wood blocks with flange that fit into the cup openings in the bottom of the seed box. My blocks had sharp corners and the openings are a bit rounded so it too a bit of pounding to put the blocks in, but then then didn't pop out either. Used to be JD had a part for that task of blocking off rows.
I bought a small flat seed. To set the rate, I jacked up one wheel, put a chalk mark on the tire and with a pile of corn over one seed cup, I turned the wheel ten turns. I measured the wheel circumference, then times ten I knew the distance covered. A paper sack under the opener caught the seed and I counted them. Spacing in the row was not good, drill seed spilling cups never are. I found about 2% of the seed were split and probably not viable just going through the drill metering stuff.
The 35" rows picked OK with a 36" combine head but those are getting rare around central Iowa. I wouldn't try it now. Maybe go for 28" rows. But I have a cyclo 400 seed spiller (but it counts good, just bunches the seed in the row) and a JD 7000 planter that I've set up for no till and it got me yield last year to match the neighbor's with their new expensive planters. 80% more than the yield I got with the drill. Fertilization had a lot to do with that also.
Planters, like the 7000, do put the seed in the row more uniformly, and that makes a better yield.
But the grain drill will plant small seeded corn. The corn would do better with press wheels to close the trench and cover the seed. Corn needs to be down to moisture 2 or 3" down often, or it doesn't come up even and the late stuff acts more like a weed than a corn plant and looses out on nutrition.
Gerald J.
