NH 273
bnbfarms
02-11-2008 18:00:03
I am looking for a wagon hitch for my 273 and am having a bit of a time finding one. I was going to try and make one but would prefer this to be the last option.
Also, my feeder teeth which feed the hay into the bale chamber throws springs all time. There are three sets, the front two (closest to the chamber) appear to only accomidate one spring. This seems apparent since this is only one small tiny hole in the bracket behind the pivot point for the spring end. The last set has two holes and was wondering if for some reason this should have two springs. The owners manual does not show this in great enough detail to determine what the correct setup should be.
Any help??
Chrisco
02-14-2008 03:53:13
 Re: NH 273 in reply to bnbfarms, 02-11-2008 18:00:03
here are the ruff measurements
third party image
MSS3020
02-13-2008 12:11:53
I have a 273. you need the springs to spring back feeders if not they will rideon top of hay or itleast they did for me. I put up alf. The springs I get at my local hardware store. Buy one about the same spring and cut to match the ones on the baler. cheeper and work well. Also if you bend the ends tighter they stay in better but not as easy to install.
Shale
02-13-2008 09:37:33
when you say wagon hitch I assume you mean the telescoping pipe with the hitch hole in the flat end. If so, I have one from a NH275 which is probably the same as a 273. I am in east central OH and could probably sell it.
bnbfarms
02-13-2008 20:07:46
 Re: NH 273 in reply to Shale, 02-13-2008 09:37:33
Where exactly are you located and what would you take for the hitch? I am located approx 30 mi south of Marietta.
Vally Farm
02-12-2008 17:42:51
Those springs went on our 273 also. Replaced a few of them, but they didn't like to last. Haven't bothered in over a decade or more by now. We don't have the heaviest hay, but havn't had a feed problem at all. Mike
MH
02-12-2008 07:31:02
I built a hitch for mine from scrap metal I had around here. Looked at a friends factory hitch & copied the mounting locations. Not too complicated.
bnbfarms
02-12-2008 16:40:20
 Re: NH 273 in reply to MH, 02-12-2008 07:31:02
Thanks for the reply, I will do the same if I can find someone with a hitch.
backwoodsfarm
02-12-2008 07:19:07
I luckily found a hitch for mine a short distance away. You might want to try All States Ag Parts. They seem to have a good selection of used parts. You can get the hitch new from New Holland but I think it will run you $350. The 268,269,275,278, and 310 I believe have the same hitch. As far as the feeder tine springs, that could be a # of problems. Installed wrong or worn out parts. Send me an email and I"ll try to take a picture of the feeder carriage on my baler so you can see how it"s supposed to be set up.
rrlund
02-12-2008 07:16:49
Where are you located? Stamm Equipment in Wayland Michigan scraps a lot of balers. Quite possibly would have a hitch.
bnbfarms
02-12-2008 16:01:47
 Re: NH 273 in reply to rrlund, 02-12-2008 07:16:49
I am in SE Ohio approximately 250 mi from the state.
rrlund
02-12-2008 16:23:39
 Re: NH 273 in reply to bnbfarms, 02-12-2008 16:01:47
Do you want their number,or don't you want to drive that far?
