John Deere Sickle mower
IBorange in TX
02-11-2008 11:27:32
I posted this in the John Deere section but got no response, so am going to try here.
I happened to rescue a JD #6 sickle mower today from the torch at the scrap yard. Would like to know if manuals are still out there for this mower. I don't bleed green, but just could not see the torch put to that mower since it is missing only a few parts. I am asuming that parts are still out there for the mower. Any help is greatly appreciated.
mb
Texasmark
02-12-2008 17:14:12
 Re: John Deere Sickle mower in reply to IBorange in TX, 02-11-2008 11:27:32
Sorta off topic but have to add it. I bought one (well used JD) and was on the way back to the house after using it the first time; becoming familiar with it. I had the sickle VERTICAL like in the picture.
I was driving down a fence row with the fence on the same side as the sickle bar. I don't know about where you live, but in N. Texas trees grow on fence rows; BIG trees with BIG limbs..... .....need I say more? Ever see cast iron split open?
Mark
Bob
02-13-2008 18:18:57
 Re: John Deere Sickle mower in reply to Texasmark, 02-12-2008 17:14:12
A polebarn door frame works, as well, to tear up a mower in "transport position".
James Howell
02-13-2008 12:45:10
Forgot to ask what part of N. Texas?
eMail open if you like.
Texasmark
02-13-2008 18:57:37
 Re: John Deere Sickle mower in reply to James Howell, 02-13-2008 12:45:10
N.E. of Dallas half way to Soonerville.
James Howell
02-13-2008 12:40:24
You need to keep the knife sharper. Then it will be able to cut those low-lying thick limbs. Just Kidding!
Yours probably broke at the yoke where the cutter bar is secured by two round pins.
One of my 3 Stooges rules is never back the tractor with the cutter bar on the ground.
I broke the yoke where the cutter bar is secured by two round pins.
After inspecting the damage, it was evident that the yoke had been broken before by another stooge.
GI FARMER
02-12-2008 06:50:49
I have a couple of them I still cut hay with mine I was able to get almost any part from local JD dealer had to wait a week but they can get almost anything. Yahoo JOHN DEERE PUBLISING and they will have all the books you need I think mine was $30. good luck. I am in OKC and know where there are a couple at in a junk yard if you need something.
Mark
James Howell
02-11-2008 14:16:01
Take another look at the upper cover (lid) on top of the gearbox housing on your mower.
It should have JOHN DEERE, a four-legged deer jumping over a log, and MOLINE, ILL.
Part No. Z 1051 H should be on the upper cover.
This will make your mower a #5 Caster Wheel Power Mower.
The manuals for the #5 mower were printed between 1936 and 1956. There are a few differences between the older and newer mowers. These manuals are available on eBay at auction from $1.99 to $19.00 depending on the seller.
Many of the parts can be found at SickleService.com.
Tractor Supply is a good source for many parts.
There are also some forum members that may be able to provide parts.
These are good mowers and will do you a good job once you get them set up correctly.
third party image
Thanks for saving the mower from the scrap man and mainland China.
Hope this helps.
long green line man
02-11-2008 12:03:04
Are you sure it is not a No. 5, or a # 9 . 5 has caster tail wheel , 9 is a 3pt. mount.
Bob
02-11-2008 11:49:23
I am NOT familiar with a #6 Mower. Is that a drawn "horse mower"?
It does not seem to be listed at DEERE Techpubs, but have you tried calling them @ 1-800-522-7448 to see if they can assist you?
