2-12 2-14 same moldboard ?
Bart CA
02-03-2008 08:43:39
Hi
I own a Ferguson 2-12" plow and wd like to use it with my MF-50 with 14"x24" tires. Did 2-12" and 2-14" had the same moldboards ? If so I'm thinking to put a 2" spacer in the frame and reposition the cross shaft to bring it to. 2-14".
Thanks in advance
Bart
Bart CA
02-04-2008 07:24:40
 Re: 2-12 2-14 same moldboard ? in reply to Bart CA, 02-03-2008 08:43:39
Many thanks to all for your replys
Greatly appreciated.
Bart
Scott PA
02-03-2008 17:08:20
If the back of your moldboard is stamped 12AAO110 it may work since that style had a gentle roll, you would also need the full width share wing, if the back of the moldboard is stamed 12BAO110 or 101517 it has a hard roll and would not work for the wider setting.
Oldoaky-2
02-03-2008 09:56:51
NO
Bob
02-03-2008 09:37:33
I have no specific Feguson knowledge, but some mfg. did that by keeping everything else the same, and using a longer SHARE.
Leroy
02-03-2008 10:15:29
 Re: 2-12 2-14 same moldboard ? in reply to Bob, 02-03-2008 09:37:33
Deere did that but not Ferguson
