JD330 round baler
haysaver
02-02-2008 16:27:01
I need to replace or resurface the drive roller in my baler. New roller is a little pricy. Was wondering if the old one could be recoated some way. I am looking for a rubber roll company or other sugestions.
Hay DR
02-04-2008 07:00:57
 Re: JD330 round baler in reply to haysaver, 02-02-2008 16:27:01
I've used these guys many times and they do fine work.
RED ROCK RUBBER, INC.
102 Clark Street
Pella, Iowa 50219
641-628-2054
641-628-2229 (Fax)
haysaver
02-04-2008 07:51:52
 Re: JD330 round baler in reply to Hay DR, 02-04-2008 07:00:57
Thanks I will e-mail them
jbruce
02-02-2008 19:52:04
For a tempory fix I painted the roller with pickup bed liner. Would do about 50 bales. Then I got a roller out of a hay conditioner made out of rubber belting stacked on a shaft. Had to turn it down to size and it really pulled the hay in. Should last much longer than the old roller.
Roger in Iowa
02-02-2008 18:09:59
If it has two drive rollers, check the other one. They have to be the same diameter or they will soon wear out again. Like having two different size tires on a locked differential.
Roger in Iowa
haysaver
02-03-2008 13:01:19
 Re: JD330 round baler in reply to Roger in Iowa, 02-02-2008 18:09:59
Yes I didn't think of that. Thanks. Going to see if a local rubber roller man. can recoat them for less than new ones.
Lee in Iowa
02-02-2008 17:49:18
Devcon.com I don't have any experince with this I just saw it on another post on here. Lee
