David Bradley hay rake transport
Dubv1980
01-30-2008 17:19:52
Question for you all.
I use an old David Bradley side delivery rake, which I am very happy with the performance of..especially for a 60 year old machine! That said, does anyone have any tricks while towing the rake to the field to limit the side to side swaying that happens on the road with the rake. I knew this was an issue going in...so I'm not suprised by it...I just wonder if anyone has any tips. Its a bummer not being able to go more than 4 or 5mph going down the road to the fields...
Chris
NEsota
02-01-2008 08:23:59
 Re: David Bradley hay rake transport in reply to Dubv1980, 01-30-2008 17:19:52
We had a rake like the David Bradley but it was labeled "Coop-Black Hawk". I would like to know who the manufacturer off these was.
msb
01-30-2008 20:03:29
Remove one of the rear wheels and it won't wobble on you. Works for me. I just lay the removed wheel in the reel basket. Only take a few seconds to remove a wheel.
Dubv1980
01-31-2008 06:37:20
 Re: David Bradley hay rake transport in reply to msb, 01-30-2008 20:03:29
Thanks for the ideas everyone..if either of these work for me it will be nice to rid myself of one of the nagging irritations of moving these things around!
Chris
msb
01-31-2008 09:39:27
 Re: David Bradley hay rake transport in reply to Dubv1980, 01-31-2008 06:37:20
Removing one wheel will work. I have a 1947 model.The date is on the serial plate. About as good of a rakes as was built in the old days and I owned or used several different brands over the years.
Leroy
01-30-2008 18:02:56
That rake was advertised to be able to be pulled at 50, yes 50 MPH on the road. There is a rubber pad brake in the rear caster wheels that will be wore out that is adjusted with a set screw. 25 year since we got rid of ours but at that time I made a new brake pad out of a piece of car tire, you have to drop the axle down to get inside the housing to see it.
Clay560
01-30-2008 18:02:52
We use an old David Bradley Rake too, works great. Most have a set screw on both back wheel housings where you can tighten up with a wrench to prevent the wheels from swaying while in transport. Make sure you loosten the screws while using the rake in the field. Hope this helps.
