Probably is, I haven't had mine apart. Apparently the problem is internal to the wobble box and you have to remove it and dismantle it. I replaced the pin this year too. Had a groove worn in the pitman arm that made installing the new one pretty tough. Thinking about that, it could be my problem. The Pitman arm has a groove worn in it by the old pin which could possibly be a source for endplay. If my current brainstorm doesn't work, I may get another arm. I can understand the hammering effect of the pitman. Have no idea how many strokes per minute that sickle gets at PTO rpm, but it's gotta be a lot and all that changing direction in an instant can easily work harden steel and cause this failure. I saw a dump truck-pup interconnect once that just sheared (like you cut butter with a knife) right at the bolt that went thru the rear of the truck for attachment. The tongue of the pup is loose and over time with it banging on the pintle it finally work hardened it and it metallurgically disintegrated. Thank goodness for the husky safety chains. As I said, slowing down my PTO will help too. One of my problems nowadays is I don't get around like I used to and it is tough for me to get under this guy and do any kind of work and being a lone operator, if I don't do it it doesn't get done. Thanks, Mark
