LOADER JD 175 FOR 1020 TRACTOR
RON ADAMS
01-07-1999 17:25:41
LOOKING FOR LOADER FOR JD 1020 TRACTOR
ORIGINAL WAS JD 175
HELP
ALSO NEED SMALL DISC, HAY CUTTER FOR THIS SMALL
35 HP TRACTOR
THANKS
Deereman
01-08-1999 20:35:11
 Re: LOADER JD 175 FOR 1020 TRACTOR in reply to RON ADAMS, 01-07-1999 17:25:41
The 175 loader was designed for utilities with MFWD, therefore it came later than your 1020 tractor. The "original" loader would be either the 48 or the 145 loader.
A 7' JD 105 disk would be ideal for your tractor. As for a hay mower, a 7' JD 350 sickle bar would be the right size. The 350 is better than its predecessors, the 30 series mowers, because it has a balanced head and no pitman arm. You might even be able to handle a 7' JD 1207 mower/conditioner.
