knotter pinion for 124 Massey baler
Tom S. in Tn.
01-23-2008 11:54:27
Need one of the 10 tooth beveled pinions held on with a roll pin, that drive the bill hook shaft on a 120/124 Massey sq baler. There is a flat ground on one side on the back so you can turn it and raise the knotter past the drive rack.
Massey # 918 020 M1 is till in the price sheet for $213.52 !!
Any used/salvage sources out there?
HELP! Tom S. in Tn.
gary tomaszewski
01-24-2008 07:33:38
 Re: knotter pinion for 124 Massey baler in reply to Tom S. in Tn., 01-23-2008 11:54:27
Deere, NH, All are the same just use model from the same era. Unless the pinion is broken, a used one will be worn and give you timing, knotting, cutting problems, at least that has been my experience.
Tom S. in Tn.
01-24-2008 08:21:37
 Re: knotter pinion for 124 Massey baler in reply to gary tomaszewski, 01-24-2008 07:33:38
What would be a good source for this part where they would know this? The problem in this region I have is finding parts outside OEM retailers where they understand substitutions.
Do you know any one with e-mail/internet access where I could inquire about this?
Thank you kindly; Tom S.
Floyd A tn
01-23-2008 16:14:04
 Re: knotter pinion for 124 Massey baler in reply to Weldon K, 01-23-2008 11:54:27
Call Kelly Cunningham @ Cunningham and sons in burns tn. The number is 615-446-2833.
He may have a used one or can get you a new one.. Gehl makes the parts for the 124 balers now..
Tom S. in Tn.
01-24-2008 08:12:26
 Re: knotter pinion for 124 Massey baler in reply to Floyd A tn, 01-23-2008 16:14:04
Thanx. I know Kelley and his wife and his dad, in fact I live about 2 mi from the new shop. His price is $85+ and he actually has some in stock. But that is still too expensive and I will braze mine back together first.
Do you know the Gehl model # for a 124? I have been told they no longer make this baler, but I do not know this factually. Searching Gehl is far easier than Massey. I appreciate any help, because that gear has to be cheaper.
Thanx; Tom S.
