Yetter Running Gear
Brad B.
01-23-2008 08:49:58
I have just inherited a Yetter running gear that was under a flat bed wagon. The front spindles that steer were frozen solid. We have managed to get one loose, but the other is being stuborn. I was wanting to see if anyone had heard of them and if there was anywhere to get parts.
Thanks for the help!
Al Clevenger
03-03-2008 14:14:51
 Re: Yetter Running Gear in reply to Brad B., 01-23-2008 08:49:58
If heating em up and hitting it with panter piss don't loosen em up . Try heating em up good and hot and drawned em with Cold Water untill cool . Then slightly heat agian and use a grease driver or power grease gun You may have to replace zert. They will loosen up. But you may have to work it some. It always works for me ! Good luck Al
RustyFarmall
01-23-2008 11:29:12
I didn't know they made running gears, but possibly did at one time. I would imagine that just about any good farm machinery dealer would be able to match up the spindles, bearings, bushings, etc. that are on the Yetter gear.
Don't get impatient with the frozen spindles. If you have a torch, warm 'em up good, and then douse 'em good with your favorite brand of penetrating oil, and then walk away.
