Du-Al 2535 Loader on Ford NAA
Bill Brennan
01-20-2008 13:53:34
Does anyone have any information about where I can find manuals and parts for a Du-Al 2535 Loader mounted on a Ford NAA. The Hyd pump drive shaft has failed at the fan pulley end.
old
01-20-2008 14:42:31
 Re: Du-Al 2535 Loader on Ford NAA in reply to Bill Brennan, 01-20-2008 13:53:34
Common problem and most of those drive shafts are pretty much generic or in other words they are used on a very large number of tractors with different pumps. I would take your drive off and then take it to a good tractor dealer and you stand a good chance they will have the parts you need. ALWAYS replace the shaft and the pulley hub at the same time or you will be replacing the shaft and hub soon after. BTDT and found out if you only replace the one part to old hub will eat up the new shaft very fast
