Source for JD 336 used pan kicker?
Daniel (PA)
01-17-2008 08:04:12
Looking at a used JD 336 baler with some wear on the pan kicker. Can anyone suggest a source for a used replacement kicker for this baler in PA or close by? I live in west central PA. Any other things to look for in this baler? Thanks
wayne in pa
01-17-2008 13:48:18
 Re: Source for JD 336 used pan kicker? in reply to Daniel (PA), 01-17-2008 08:04:12
I have a complete 30 kicker it came off a 336 baler $500.00 for everything. I'm in east centeral Pa. Schuylkill Co.
Wayne
Daniel (PA)
01-17-2008 14:57:51
 Re: Source for JD 336 used pan kicker? in reply to wayne in pa, 01-17-2008 13:48:18
Wayne: Drop me an email regarding your kicker.
backwoodsfarm
01-17-2008 12:44:36
Do a search for All States Ag Parts. You"d be suprised at what they have. For me, it"s always been whatever I couldn"t find.
Leland
01-17-2008 11:31:15
find a welding or sheet metal shop to make you one .
M Nut
01-17-2008 11:26:44
Know of a John Deere dealer here in North Central MN that has two. A #30 and a #40. But, that is a long way from PA.
Roger in Iowa
01-17-2008 09:15:19
I doubt if you will find a used pan. If you do, it will be worn also.
Might want to check the return spring inside the kicking cylinder. They can fail and cause the pans and arms to break up.
Roger in Iowa
