bearings on plunger NH 268
J Heitkemper
01-10-2008 16:50:56
Hope someone knows how to repair a NHolland 268 ... Plunger roller bearings are needing replaced .. How do you get to some of these? . Will we have to disconnect plunger arm and roll the plunger out the Back ? Thanx Jim
ArleninOr
01-10-2008 17:39:45
 Re: bearings on plunger NH 268 in reply to J Heitkemper, 01-10-2008 16:50:56
As Dave said but you also need to pull the wedges out of the chamber I think I still have a book on that model as I sold the baler and had 2 books
pa dave
01-10-2008 17:04:42
we did the bearings on our 271 (same as your 268) you will have to pull the plunger out the back, then you can easly get to all the bearings, they are common bearings, can be purchased at any where that sells bearings. you will need a manual to adjust the bearings once the plunger is back in the bale chamber good luck
