What size disk
Ross Johnson
01-06-2008 20:24:10
HI all, What size disk would be best suited for allis chalmers 190xt. Would like the biggest it will handle without overworking tractor. thanks in advance
1206SWMO
01-08-2008 22:55:45
 Re: What size disk in reply to Ross Johnson, 01-06-2008 20:24:10
16 ft should be no problem.I used to pull a 16 ft 470 IH with a 200 AC with duals.
kyhayman
01-08-2008 15:06:29
Anywhere from 12-16 feet. If you're running duals traction shouldnt be a problem. If it starts getting hot, drop down a gear. I nomrally pull a 12 foot with a nominal 86 hp. On the ones that dont have the pumps juiced up they do fine all day long. On the tractor with 14,000 hours and the pump turned up 2 full turns it wants to get hot pulling the same disc in the same ground.
steveormary
01-08-2008 09:15:45
I pulled a 15' MF disk with bar harrow with a 706 ger. No duals so at times I had a traction problem. 4low at about 4.75mph.
steveormary
J.C.in AZ.
01-07-2008 16:42:35
I pulled a AC 12" wheel disc with my 190,My neighbor had a 190 XT Diesel and pulled a Kewanee 13'6" wheel disc.We both had duals so we were comparable that way but that 190 XT was way more powerful than my plain 190 gas.
Ross Johnson
01-07-2008 15:09:42
thanks all, I will be using for spring tillage, I chisel plowed in fall. Loking to get seed bed ready for planting corn. I will be using duals also. Any recomendations on a chisel plow for fall tillage in stalks. that will be next purchase after disk. About 50 acres for now hopefully more in future. Thanks again
Allan In NE
01-07-2008 05:49:42
All depends on what you are going to disc.
I have a 15' disc that will just absolutely work the snot out of an 80 horse tractor if used in loose ground.
Pulls it handedly for normal "discing". Your XT ought to be a nice match for an 18 footer in stalks or the like.
Allan
third party image
MF Poor
01-07-2008 02:47:02
An uncle of mine had a 190XT way back when. He pulled a 16' Kewannee disc. That was with duals
JMS/.MN
01-06-2008 23:25:25
The XT should crank 93 pto hp. JD 4020 is 94-96? Would typically pull an 18 foot here on heavy clay soils, but mine was a JD 210 with the cone blades,so a 14 foot was a good match for the 4020 in the 70s. Most disks are concave, not cone blades. My 3020 would not pull the 210 decently in plowed ground. I think they were 20 inch blades. Spacing makes a difference too- wider spacing means fewer blades, and blades turn the soil-more blades take more hp. And always, dual wheels. Sixteen foot of any spacing or common diameter might be a good match for your 190XT for any tandem disk. If you"re talking an offset plowing disk with 26 inch blades that is heavy enough to cut 8-10 inches in standing cornstalks, then you"re down to an 8 foot machine. Friend of mine pulls an 8 foot Bushhog plowing disk in North Central MN, light ground, with his XT. I bought a 14 footer from paul"s neighborhood a few years ago, and it"s a good match for a MFWD that cranks 190hp.
georgeky
01-06-2008 23:13:26
10 foot.
paul
01-06-2008 22:44:47
How many hp is that?
Are you looking to pull in fall on hard ground? Or in spring in loose soft ground?
Are you looking for a light finishing disk, or an aggressive primary tillage disk?
My 85 hp tractor will toy with a 20 foot light disk in fall, but a heavy tillage 12 foot disk would be a hard pull for my 135hp tractor....
--->Paul
