INFO on JI Case running rears
Tim in Indiana
01-06-2008 07:45:30
I just purchased a JI Case running gear site unseen, so I don't have any of the numbers off of it, does anyone know if these were good straight pulling running gears? I know it depends on the amount of wear, however I was wondering in general if they were a good gear. This one has a factory bed and hoist under it I'm very excited on getting it home any info would be much appreciated thanks.... Tim
Broken Rod
01-12-2008 14:19:42
 Re: INFO on JI Case running rears in reply to Tim in Indiana, 01-06-2008 07:45:30
I have a running gear I broke the cast hub and the rim. It is a model 650 but cannot read anything else. Any ideas what it is or where to begin to get any parts
J.C.in AZ.
01-07-2008 16:49:56
I had two 10 ton Case Gears with large Wisconsin Self Unloading Forage Boxes on them and they were excellent . I used them for Chopping Haylage,Dry Hay, Straw and Corn Silage and pulled them behind a Fox Chopper with 190 AC power.
2t2@ia
01-06-2008 16:06:54
I've owned several older Case gears of a couple of models. I do not remember the model numbers. They are excellent gears.
msb
01-06-2008 13:32:05
Cobey advertized that their wagon could be pulled at 60 miles per hour. Don't recall any other manufacturer doing that.
Don-Wi
01-07-2008 07:28:02
 Re: INFO on JI Case running rears in reply to msb, 01-06-2008 13:32:05
Better Bilt made some excellent gears. I pull them up to 65 MPH empty on a regular basis. We've got one Cobey on the farm, but we've only had it for a few years and it's under a gravity box we only use 1 or 2 times/year. Needs to get the steering tightened up to really pull straight.
Donovan from Wisconsin
flying belgian
01-06-2008 10:24:19
I have gears of all colors and the best trailing is New Holland. second best is Case. I have gone through front ends of all so all are tight.
Tim in Indiana
01-06-2008 11:22:15
 Re: INFO on JI Case running rears in reply to flying belgian, 01-06-2008 10:24:19
So you"re saying they pull well, but you say that you have tighten yours all up, I"ll let you know about mine in a few weeks ok thanks for the info
LA in Wi.
01-06-2008 09:34:00
Case running gears of the 1940s and early 1950s were very good, tracked nice and straight, and were trouble free. As I recall the wheels were Case orange and the rest of it a dark shade of green. I know of an excellent Case running gear in central Iowa, but I don"t think it"s for sale.
LA in Wi.
01-06-2008 21:37:15
 JI Case running gear colors in reply to LA in Wi., 01-06-2008 09:34:00
Case running gear colors: I had it backwards on previous post. Green for wheels, orange for frame, etc.
John730D
01-06-2008 08:32:42
Case running gears were the best pulling ones we ever owned. I would tke a case over any other brand. Of course this was 30 years ago so I am sure there are better ones out there now. But for an older gear they were the best.
If you get tired of it let me know.
Tim in Indiana
01-06-2008 11:23:39
 Re: INFO on JI Case running rears in reply to John730D, 01-06-2008 08:32:42
Thanks and I'll keep you in mind if I decide to sell it and get a newer one thanks for the info
