Going to go check out a used NI 5212 discbine that's coming up on a local auction close by. It's a 12', side pull discbine. Supposedly the cutter bar has been rebuilt.Just looking for tips on what to look for when checking out the cutterbar and gearbox on one of these, or any other discbine for that matter. I kind of had my heart set on a center pivot 10-12' machine, but the side-pull 5212's seem to be a lot more prevalent around here. I've heard a lot of good things about the New Ideas from a durability standpoint, and from being relatively simple to work on if something does go wrong with the modular cutterbar and shaft drive gearbox. There's a Gehl 2412 on the same auction. I've run a few of these before and liked them, but have heard the cutterbar's are a bit more difficult to repair if problems occur. I know buying a used discbine is playing with fire, but I really can't afford to drop the money required even for a new 9' disc mower. I run over 30 acres of my own hay annually, and have somewhere in the area of 40 acres of custom work, which might increase, so I think a bigger discbine is justified. Any thoughts you guys have are appreciated.
