Pto shaft shear bolt
Scott Magyar
04-12-2000 08:32:51
Are the pto shaft shear bolts a grade 2 bolt? A guy down at the hardware store said that grade 5 is ok to use but i am not sure.
SCOTT
04-12-2000 16:42:31
 Re: pto shaft shear bolt in reply to Scott Magyar, 04-12-2000 08:32:51
FIRST TRY A GRD.2. IF YOU CONTINUE TO SHEAR BOLTS THEN TRY A GRD.5. BUT IF YOU HAVE A VERY LIGHT CUTTER YOU COULD DAMAGE THE PTO. THERE ARE ALSO MANY BRANDS OF CUTTERS THAT USE METRIC DRIVE-LINES. IF THE BOLT DOES NOT FIT PROPERLY IT WILL NOT SHEAR, BUT SMEAR. TO HELP FURTHER WE NEED TO FIND OUT YOUR BRAND AND MODEL.
oleHitchPin
04-12-2000 09:32:13
I tried grade 2 bolts, for shearbolt, with my wifes SERVIS 5' mower. I was changing bolts every 2 minutes. They were actully causing MORE damage to the input shaft. I now use grade 5 and check them before each use. if worn, replace. (this avoids the hammering of a worn bolt on the shaft hole)
