JoshuaGA
01-04-2008 18:48:57
Re: Opinions on two round balers needed in reply to fudpucker, 01-01-2008 09:40:34
Have no experience with Vemeer, but run New Holland. Some points to watch on New Holland. Check the gears on the rollers. If they are wore excessivley, you ar looking at a baler that is a potential money pit. Its probably been run in dusty conditions, and all the bearings are probably wore, pickup is wore, sidewalls wore, you get the picture. Not to mention, working on those rollers is heavy and hard work. Look at the rollers. If they are wore smooth, especially the floor roll, it will be a bear to start a roll, especially if your in a slick crop like straw. Only way to fix it is to either use a gritty paint or weld beads on the floor roll, maybe on upper rollers if really bad. Check the belts. Look at the splices for stress. Had a baler that kept pulling splices. Got to the point where me and another guy could resplice and thread those belts in less than 10 minutes. Turned out belts were two foot short. Check pickup for excessive play, missing teeth, wear on pickup. Check all the chains, belts and cables, and bad bearings. Check twine arm drive for excessive wear. Then, If it checks out, consider it, otherwise, save your money. HTH.
JoshuaGA
