3020 john deere help
jed in IN
01-01-2008 07:30:49
3020 with powershift has a knock back around the pto when the pto is engaged any input on the problem would be greatly appreciated. thinking about buying the tractor i was wondering what the value might be ? it is a gasoline motor.thank you for your input .
kyhayman
01-01-2008 11:31:04
 Re: 3020 john deere help in reply to jed in IN, 01-01-2008 07:30:49
Gas, with a narrow front would bring between 3000-3800 here depending on tires and sheet metal. Depending on how noticable the knocking is, knock 500-1000 off depending on how noticeable it it. Id speculate that there is a caged bearing in there that has failed. Over the years thats been the main PTO repair that I have had to perform on these tractors.
garrett1
01-01-2008 09:21:36
it sounds like there is a tooth broke off a gear that drives the pto. these gears are located betwen the transmission and the bell housing. the tractor will need to be split to fix them. i have a 3020 gas with a cab, aftermarket wide front and power shift, dual hyd. i am asking 5500 for mine to give you an idea on value. i am in NE iowa.
Bob
01-01-2008 09:18:25
Possibly a tooth out of a gear or a bad bearing.
