BC: George was well on his way to fame and fortune, then he got rid of those little MF tractors. He claims it's been down hill ever since. LOL On another note about the Ford flex disk, I may be a poor one to ask. According to YT discussion Ford disks were built by Oliver. That being the case they very likely are a good disk. One has to remember, most of these companies did not always sell the same product line in Canada as in the US. The Ford disks I've seen here in Canada definitely where not made by Oliver, Cochshutt or White. I had two Cockshutt disks, same as Oliver, however mine were wheel controlled tandem disks. Over the years I've seen several neighbors with those 3 point MF disks. Definitely best best light mounted disk I've ever seen. I was so impressed, I bought one two years ago and got rid of my IH light mounted disk. This MF-25 is the same disk as in your photo, 24 blades and 18" blades. It will go axle deep, first cut on just about any plowed ground, and doesn't need to be set anywhere near the sharpest angle. It's really too much load for my Farmall 130 or 140, both pulling and lifting. I have thought of taking one blade off each gang turning it into 20 blade disk, however in doing that, I'm not sure I'd be able to pull it set at the sharpest angle. I think the 4 blades, spacers and extra arbor, would help on my hydraulics, from a lifting point of view. I guess I'll just have to buy a MF-35 tractor, and unlike George, increase my riches.
