Hugh Others - 3 Point Hitch Disc
BC in TN
12-19-2007 18:40:34
third party image
Hugh & others:
I'm looking at a John Deere disc - I believe the model number is 617. It is a 3 point hitch model. The description of the disc calls it a "fully adjustable, offset to conventional". I sure would like to know more about this disc - do any of you have any knowledge of it? How much tractor HP needed if it were a 6 footer, if it were a 7 footer?
I simply disc some old, rocky ground, seed it and run a cultipacker over it for a few small square bales of hay. I would also use the disc in a garden. I likely would trade some other implements for this one. I'll try and post a photo. I believe the "Offset" refers to the alignment or angle of the disc. I see that it doesn't have "cutting" blades on the front. Are those cutters important for tearing up sod?
MF Poor
12-21-2007 03:31:35
 Re: Hugh Others - 3 Point Hitch Disc in reply to BC in TN, 12-19-2007 18:40:34
Disc blades come in two shapes. Cone or parabolic disc. A typical parabolic disc, 18" in diameter, will loose an average of 7% of its offset when 1" radius is worn away. Less than 10% is lost when 2" radius is worn away. The rate of loss of offset decreases in percentage as the wear continues due to the parabolic shape.
While some wear does effect the performance, it takes significant wear to noticably diminish the usefullness of a disc blade. Nothing like new. But who's to say that "new" isn't more than adaquate, while all along the serviceable wear limit is 2", 3" even 4" less than original diameter? It's highly unlikely that manufacturers would use a disc blade that is functionally obsolete with 5% or 10% wear. There's a difference between WORN and WORN OUT. From what I can gather, 20% wear (reduced diameter) is considered by product manufacturers to be with-in service limits. That would mean an 18" disc blade could loose slightly more than 3-1/2" of it's diameter and still be within service limits by most standards.
And from my own experience, disc blades remain very much useable and functional until wear approaches 3" from original diameter. They aren't scrap as soon as the paint is worn off.
Hugh MacKay
12-21-2007 07:35:47
 Re: Hugh Others - 3 Point Hitch Disc in reply to MF Poor, 12-21-2007 03:31:35
MF Poor: No one will argue what you're saying, however there are disc vendors out there selling disks with 18" blades and calling them new 16" blades, and the concave is different on the two. I believe we have a duty to warn the novice of the difference.
MF Poor
12-21-2007 08:24:24
 Re: Hugh Others - 3 Point Hitch Disc in reply to Hugh MacKay, 12-21-2007 07:35:47
"We have a duty"? If you say so.
Me thinks you may be over-engineering a very simple concept. We're discing dirt here, not flying to another galaxy.
The difference between an 18" disc blade worn to 16" and a new 16" is so minimal that the results of using either would be virtually undetectable.
Iowayalso
12-22-2007 18:58:53
 Re: Hugh Others - 3 Point Hitch Disc in reply to MF Poor, 12-21-2007 08:24:24
MF Poor, you have a problem and please take it elsewhere.
Hugh MacKay
12-21-2007 08:40:30
MF Poor: You must be buying different disk blades then I am. I can pick them out 100' away. I had an 88 blade Bush Hog with 20" blades. Farmall 1066 didn't run away with it when new, however when they got to 18" the tractor played with the disk. I changed them at 16", and by that time they were close to a flat plate. I've owned 4 other new disks lifetime, the experience is quite the same.
MF Poor
12-21-2007 08:49:46
 Re: Hugh Others - 3 Point Hitch Disc in reply to Hugh MacKay, 12-21-2007 08:40:30
Not my first rodeo either. Did it occur to you that when the disc blades wore, they might not have been working as deep? That would account for a significant difference in your drawbar load. The significantly lighter drawbar load being from an ever-so-slight decrease in disc offset is more of a snipe hunt than a legitimate reason.
Hugh MacKay
12-21-2007 09:16:18
 Re: Hugh Others - 3 Point Hitch Disc in reply to MF Poor, 12-21-2007 08:49:46
MF Poor: Of course it wasn't working as deep, any bone head could figure that out.
MF Poor
12-21-2007 09:22:03
 Re: Hugh Others - 3 Point Hitch Disc in reply to Hugh MacKay, 12-21-2007 09:16:18
Then you're good to go!
MF Poor
12-20-2007 02:48:49
I had one of those Deere 3-point "offset frame" disc's a while back. They're offset like that to eliminate the uncut strip usually left in the center of the front gangs. That model is a fairly decent disc for a 3-pointer. I never was a big fan of John Deere disc's. 3-point disc's don't impress me either, but it's hard to beat their mobility and manueverability. The frame isn't exactly what you'd consider heavy duty or heavy weight. It'll need a little extra weight in tough sod conditions no matter which blades or what shape the blades are in. All things being equal, you could do worse.
Notched blades do dig a little better in sod, but they also tend to wear faster than plain blades, as well as they'll tend to break easier especially in rocky conditions.
Hugh MacKay
12-20-2007 01:48:01
BC: I've never had much experience with John Deere disks. I had a chap do some disking for me with a slightly larger version of that same disk. His was 24 blade and a very effective working disk.
The important items to watch for in a used disk are; blades, bearings, arbor bolts and spacer spools. Make sure you are getting the size of blade advertised. An 18" blade with 2" worn off doesn't make a 16" blade, the concave is different on the two. Cut away or notched blades are good, but I wouldn't turn my back on good blades without the notches. Make sure your getting 1" or larger arbors, bearings and spools. Make sure the spools are 5-6" diameter on the back side of each blade. Heavy gauge blades, along with 1-1/4" arbors, bearings and spools add weight fast, plus add a lot of strength to the disk.
Hugh MacKay
12-20-2007 15:17:24
 Re: Hugh Others - 3 Point Hitch Disc in reply to Hugh MacKay, 12-20-2007 01:48:01
You out of order, 18" diameter minus 2" diameter equals 16" diameter. I never did indicate anything about radius, and yes 2" less radius would be 14".
oops
12-20-2007 17:33:54
 Re: Hugh Others - 3 Point Hitch Disc in reply to Hugh MacKay, 12-20-2007 15:17:24
"minus 2" diameter" translates to 1" worn off. Your original of 2" worn off does equal a 14" diameter. Draw it out on paper to scale and check it.
Small Point of Order
12-20-2007 14:09:49
18 inches diameter minus 2 inches = 14 inch remaining diameter.
Diameter is reduced equally around the circumfrence of a circle.
That is all
Robert
