nh and case Discbines
txnpuller
12-19-2007 18:03:06
HI every one.IS A CASE DCX101 THE SAME MOWER AS THE NEWHOLLAND 1411? thay look the same.
Josh in WNY
12-20-2007 14:25:58
 Re: nh and case Discbines in reply to txnpuller, 12-19-2007 18:03:06
Yes, they are the same. If I remember correctly, New Holland and CaseIH are owned by the same parent company and New Holland makes the CaseIH mowers and balers. The only difference is the paint. (NH might even make CaseIH's wheel rakes, but I'm not sure)
I tried a used one this summer that I was looking at buying (someone had traded it to a local John Deere dealer). It was a NH 1412 (impeller conditioner). It was a beast to run compared to our old NH 488 haybine, but did a nice job until the gearbox that the John Deere dealer supposedly fixed took a crap (didn't even make it through 2 acres)
If I could afford one, I would be hard pressed to buy anything else. Kuhn and John Deere might be the only other ones I would look at. I ended up buying an older CaseIH 3309 discbine (made by New Idea) and it seems to be a nice mower, but not quite as new as the 1411/1412 New Hollands.
Hope this helps.
Josh in WNY
Josh in WNY
12-20-2007 14:25:30
Hope this helps.
Josh in WNY
