MF 32 loader valve freezing
Steve IA
12-19-2007 11:19:48
The MF-32 loader mounted on my MF 135 will freeze the bucket dump valve when below freezing temps. The arm lift is not a problem. It will eventually thaw, but I'd like to drain the obvious water out of the valve. There are a couple of nuts that may/may not be correct to drain the valve. I don't know jack about hydraulic valves and don't want to take nuts off that my be holding vital parts that will spring all over the shop when removed. I'm guessing B below.
C= offending valve
B= Big nut directly under the valve shaft
A= Smaller nut in the area.
third party image
Thanks for helpful responses.
Steve
Duane(Pa)
12-19-2007 17:52:25
 Re: MF 32 loader valve freezing in reply to Steve IA, 12-19-2007 11:19:48
I don't think I would take any of them off. I would look for a product called Seafoam to add to the system. Seems to work pretty good. DW
Steve IA
12-20-2007 02:34:12
 Re: MF 32 loader valve freezing in reply to Duane(Pa), 12-19-2007 17:52:25
thanks, Duane. I'm not familiar with SeaFoam but looking at the website can't see any product directly related to hydraulics. Which product are you refering to and how do you use it? Thanks again.
Steve
Duane(Pa)
12-20-2007 19:44:13
 Re: MF 32 loader valve freezing in reply to Steve IA, 12-20-2007 02:34:12
Bugs be gone.... Only kidding! I used the Motor Treatment. It says something like "Dries wet hydraulic systems" on the can. I never would have believed the mechanic in a can claims but have seen this stuff work on faulty systems. If you look at the MSDS file on their web site, you will notice there's a fair amount of Isopropyl alcohol in most of their products. I imagine that's whats doing most of the work. It's worth a shot, best wishes. Duane W.
Steve IA
12-24-2007 03:16:48
 Re: MF 32 loader valve freezing in reply to Duane(Pa), 12-20-2007 19:44:13
Duane,
I removed the cup B and it had 1/2" of water in it. When frozen, that ice would keep the valve spool from going down which is exactly what was happening. I removed the water and the valve worked perfectly at +9F yesterday morning. Tractor sat outside before I bought it so suspect rain leakage. Thanks for your help.
Steve
Duane(Pa)
12-20-2007 19:47:11
It comes in about a 16 oz. can I would just dump the whole thing in there and see what you get. DW
