small disc
banjo
12-17-2007 19:28:29
whats one of them little 3 point 4ft garden disc usually run price wise? feller down the road has one i"d like to get for my super a. I built a 3 point on the back and think it would do pretty good in the garden. When i get threw with a row or 2 i could disc it up and plant the next crop without messin up the rest of the rows.
MF Poor
12-19-2007 15:51:39
 Re: small disc in reply to banjo, 12-17-2007 19:28:29
Most of the better equipment manufacturers use "lbs per blade" as a comparison of disc models. No matter what the condition of the blades may be, if a disc is too light for the conditions, it'll just roll along on top of the ground. Most of the small angle iron framed 3-point disc's you can buy today are just too light for anything except ideal conditions. (loose, plowed ground) They need some weight added. How much weight usually depends on how much the tractor can deal with. Some of the 3-point disc's built with box tubing construction will have a little more built in weight. You'll find 'em as light as 20 lbs per blade on up to several hundred lbs per blade on big primary tillage disc's. 40 to 50 lbs per blade is about the absolute minimum I'd want. (1000 to 1200 lbs for a typical 7-1/2'er/ 650 to 700 lbs for a 5'er)
Hugh MacKay
12-19-2007 03:10:30
Banjo: My experience has been those little disks in good condition run $500. plus. If you buy one with worn disk blades and bad bearings, you'll soon spend the $500. Contrary to what your being told, if a disk requires weight the blades are worn out. Once a blade gets 2.5" smaller than it was from the factory, the best of the concave is gone. In other words it's no use calling a disk with worn out 18" blades, a 16" disk.
If you want a good disk, buy a 12 footer with 4 bearings per gang. Cut the 12' disk down and build two 3 point hitch disks. Again watch that concave, if it appears to be 16" blades then compare them with a new 16" blade.
There is a guy on Farmall page Steve Mason who bought a 44 blade trailer disk for $100. He cut it down and built a 24 blade trailer disk to use behind his Farmall C. That was close to 7 years ago. Because that disk had 4 bearings per gang he has enough parts to build a 20 blade mounted disk. What did he gain? He has a disk with 18" blades, 1-1/4" arbor bolts, heavy bearings and spools. Basically he has a disk that will cut with the best of them, and it cost him $100. plus 3 days fabrication in his shop.
He scared the hell out of me as I talked him into doing this. We spent 3 days and about 6 full screen e mails each, discussing how to do this cut down. On day 4, 5 and 6 I never heard tell of him. On day 6, I said to my wife, the disk manufacturing is not going well and Steve Mason is so annoyed with me, he will never speak or write again. Well, on morning 7, I get up to find 3 photos in my mail box of a Farmall C disking with a 24 blade trailer disk, in western Iowa, close to a 1,000 miles from me.
I use the same type of disk behind my 140 or 130., a big disk cut down to 20 blades. You get heavier gauge blades, heavier bearings, heavier arbor bolts and spools. Those little factory 16 and 20 blade 3 point disks use light gauge blades, usually 7/8" arbor and the spools may as well be tin cans. I just sold one of those, 16 blade disks and he needs 8 new blades. I had planned on scrapping all but the frame and using it for another created disk.
banjo
12-19-2007 06:45:18
 Re: small disc in reply to Hugh MacKay, 12-19-2007 03:10:30
Hugh, i was just mainly thinking out loud. I seen it sitting there and thought that it would be light enough for the super a.
I dought if i ever get a price from him, as from what i gather, he wants other folks to offer first. He refused ,till it is a new price.
I didn't know this guy was so high on his stuff till i got to talking with other folks that know him. I'm always looking for a bargain if i can justify i can use something.
Brendon-KS
12-18-2007 19:30:36
You might be better served by a 4' version of a larger disk such as a King Kutter or something like that. As the others have said, the garden tractor type disks with little 11" blades don't accomplish much. You want something that weighs at least 100 pounds per foot of cut to do a decent job. Disks such as this go for a lot more, though. If you can find them used they typically go for nearly new price. Get one with notched blades at least on the front as it helps with cutting trash.
banjo
12-18-2007 22:36:57
 Re: small disc in reply to Brendon-KS, 12-18-2007 19:30:36
thats what this one looked like. I know it had the notched disc in front but cant remember if the back ones did or not.
probably isnt going to matter as the guy that has it thinks his stuff is worth more than anyone elses.
He bought a place that had this stuff with it. Had a farmall H that needs work, does run but smokes the whole time, front rims bent in several spots,belly pump not working, monkeyed up wireing, mismatched rear tires,no muffler,carb leaks like sive. he thinks its a $2000-2500 tractor.I think he is going to own it for awhile
tractormiallis
12-18-2007 15:47:06
You have to weight them down to cut anything, even then they dont do much of a job, tandem pull disk is much nicer. The 3 point might work ok if its just a small garden and does not have much residue on it.
DiyDave
12-18-2007 03:53:35
I've seen em go up to 200 bucks at an auction before, but I've used em before, and here's a pearl of wisdom for free-They don't work worth a S**t, if the disc diameter is less than 14".
