replacement coulters and hangers
StuBC
12-16-2007 10:11:58
I have an unknown make 2 bottom 3ph plow. No markings. It has no coulters at all. Any place to buy the whole coulter set new aftermarket? Hanger and all.
Stu
Earl - IL
12-19-2007 18:25:38
 Re: replacement coulters and hangers in reply to StuBC, 12-16-2007 10:11:58
Can you post a picture . Maybe we can ID your plow. Does it have a number stamped on the back of the moldboard or plow share ? Earl In Illinois
StuBC
12-20-2007 17:33:55
 Re: replacement coulters and hangers in reply to Earl - IL, 12-19-2007 18:25:38
I will post a photos set guys, I can see that you are hungry for the challenge! Thats cool. I am sad that in my 10 year experience now that I have no idea.
So I will pull it up in the air, knock the snow off and post some shots.
Stu - merry Xmas
Earl - IL
12-20-2007 18:30:39
 Re: replacement coulters and hangers in reply to StuBC, 12-20-2007 17:33:55
Sometimes the plow is easier to ID by the moldboard number Or the share number. Pus a Photo or 2 or 3 . Earl
2t2@ia
12-18-2007 18:45:20
Hi:
I agree with Tim that a set from a plow about to be junked would probably be the best solution. I always used coulters when I plowed. Many did not, which is one of the reasons that used plows often do not have them. They were put in a corner somewhere and sold for scrap eventually.
Tim(nj)
12-17-2007 09:51:40
King Kutter and Leinbach both sell complete coulter and shank assemblies for their plows, but it you don't have clamps . . . you might want to find on of those brands somewhere new (A&B Eagle Line is another that comes to mind) and take beam measurements, shank measurements, etc and see if their parts will fit your plow. Another option would be to find a bigger semi-mount plow that has fallen into disuse in favor of no-till, and see if the assemblies will move over to your plow. I did that with an old IH plow I had. Couldn't find IH coulter assemblies locally to put on, but found that a set off a JD F145 that had been retired by a neighbor and about to be cut up for scrap fit nicely.
